I recently flashed my phone to 4.1.2 ([ROM][ODIN][TAR]SPH-D710 GB27 (GB27 Modem/Kernel/ROM - Root/Stock)) and it worked. After I did that however, my recovery screen has a lot less options.
Android system recovery (3e)
Reboot system now
Apply update from ADB
Apply Update from External Storage
Wipe data/Factory Reset
Wipe Cache Partition
Apply update from Cache
I can't get to any kind of backup or restore like I used to have with the earlier version. How do I reset this menu? Can I?
EDIT: My main thing is that I can't clear the Dalvik cache or make a backup of the rom (since CWM says that it doesn't work with the 710).
Reboot system now
Its hard to tell whats stock and custom. Since you were talking about CWM I assumed it was a rooted rom and clockworkmod recovery. If not, let me know and I'll move it back.
