Umm is there any other way to turn on phone without pressin ths power button now its gettin hard the button
turn it on? You could give it a nice back-rub and dim the lights a little
While it's off, connect it to the charger and once it turns on disconnect it.
That does not turn it on, it only display a charge meter. What I would do is turn the phone off, pull the battery, and use a q-tip with high-purity isopropyl alcohol to get a little bit into the space around the button so that the gunk gets cleaned out. let it dry for 20-30 minutes and all should be well again. Then make sure you do not get dirt and other gunk on the phone.
You can take the back off of your phone with a torx driver and clean the power button with a razor blade or something similar that is REALLY thin. Build up gets around the button and makes it stick. You "might" can clean it from the outside with a very small flat head that will fit between the sides and clean some of that gunk out.
And void your warranty in the process.
Lol Thanks for sharin
