Root Power Key
abezzilla99
Hi, my power button recently stopped working and was wondering what is the best way to go about making another button wake the screen and using either the same or a different button to make it go to sleep. I have tried using an app that puts it to sleep when the icon is pressed but I would much rather use a hardware button. Thank you.
You would have to remap a key inside the firmware. Like say turn your camera button into the power button?
I forget but is there options on the sleep and wake buttons in the spare parts or other system settings under velocity settings menu?
I use todo key remapping on android tablets... maybe i can do something for the ally il look into it
