ahoogst
Is there a way to specify custom brightness levels instead of using the preset options included (Auto/Dim/25%/etc.)? The reason I ask is because the 25% preset is actually 40% on my TB. For now I'm using Notification Toggle to change brightness from within the notification menu. You can also use it confirm that the power control 25% is actually 40%.
) have these options
