If you remove it, you can't use the power menu to power down your device. Just causes it to reboot
Gotcha. I was asking cause I can't shut my screen off at the power off button so I thought that might be the problem but its not
No. I'm on #2 and decided to try out that revo rom and noticed my screen wouldn't shut off so I went back to #2
I can't backup my roms anymore otherwise I would have jus restored
I did my wipes...even flashed #2 2.4 and nothing has changed. I cant backup my roms with cwm. I get a message:
sd card marker mismatch
Error processing ROM manager script
Please verify that you are performing backup, restore, or rom manager installation from rom manager v4.4.0.0 or higher
/temp/recovery.log was copied to sdcard/cwm/recovery.log
Please open rom manager to report the issue
...and I have no idea what that means and ever since I got that message I haven't been able to backup my roms
but my cwm is weird...when I open RM it says v5.0.2.0 then when I'm in recovery it says v5.0.2.8 but it states my current RM is v6.0.0.1 I think lol.. I know its a 6 but its not touch. If I go thru RM and flash it will it brick my phone? I just know there's been issues with it
