Root Power off widget
foxII
I remember seeing a thread about a widget that you can use to completely turn off the evo 4g instead of the wear and tear on the power button.
Anyone know the name of this widget, or an app that will do it.
Quick Boot Plus is the app you want, it works perfectly...
It Reboots, Boots into recovery, Boots into Bootloader, Powers Off and also Hot Boots. That is all thru the app, you can go thru shortcuts after the app is installed and add shortcuts to each individual boot preference including Power off to your screen. If ya need any help let me know
You guys rock!!!!!!!!! I actually had quickboot installed as part of a package. I'll give that a try first........ Thanks
Update:
Just tried quickboot and phone went instantly off. The only question that I have why does this work so fast and the stock power off take so long????
Is this like using the power button to turn off a computer instead of letting it boot down. If so can it do damage to the system files by not allowing them to properly be ended.
