Don't they replace the outside so its new
Can't I return the the phone and ask for a new new one? I didn't buy a used phone
You may have bought a new phone. Then once you use the phone it becomes a used phone.Can't I return the the phone and ask for a new new one? I didn't buy a used phone
I bought a refurb and won the refurb lottery...my phone was perfect physically and I have never had a reboot.
. Now, I'm not a fan girl, but I did buy a refurbished ipad in April and that thing looked BRAND NEW! The description did say that they do replace the whole body and/or screen when they sell you a refurbished ipad.i wouldn't be surprised if they replace everything. i mean the kickstand on these things starts peeling after a couple weeks.
FWIW, my one and only CLN phone (thunderbolt) was absolutely MINT minus 1 dead pixel. however i am still having signal issues, so the 2nd CLN is at my house waiting for me. i will update on its status. i really dont want a Charge, but if this one takes a dump i am getting one.
After 3 tbolts I went to a charge after an obscene amount of bitching... now I'm going back to a tbolt. Don't do it to yourself trust me... its quite slow comparatively, the wifi is so bad, the call quality is inferior to the bolt and it might as well not have google maps cause good luck getting a gps lock.. and if you leave it on auto brightness the screen is only slightly more saturated and the same resolution... battery life on 3g is about the same, can't speak about 4g... no LED sucks balls and the camera is not quite as good as the HTC..it needs a new browser, the 3.5mm jack on the sammy is better subjectively ill give it that... and an hdmi out, thats it. I played with both for a couple days before I returned the bolt...
