Root pREVAIL dEAD
charlynn42
pLZ HELP MY SAMSUNG PREVAil had shabby 9 and kernal until a sam update downloaded....now it wont even pwer up ...is there an hope
You got an update notification while running shabbymod? That's really odd. It's even stranger that the update did something.
Anyways, try getting into recovery and flashing the nandroid you should have made at some point. If that doesn't work, hail odin
thanks had to buy a new one....now new problem.....whats com.phoneupdater12....is it what i think it is and which is an invasion of privacy??? any tips on tracking the tracker who put it on my phone....? some heads are gonna roll
Sounds like the Feds are on to you! You need to wrap your phone in tinfoil to stop them from getting a GPS fix on your location then throw it off a bridge. If you have a computer its probably bugged too. You need to wrap that in tinfoil also then throw it out the window. This will disable any tracking hardware already installed. Next you need to make a tin foil hat and put it on. This will block all incoming gamma neutron reactor rays and stop the evil mind control machine dead in its tracks.
A word of caution though my friend you need to be very careful trying to track the tracker they have eyes and ears everywhere....
I think, and I stress this is just an opinion your phone got the over the air update, for EE14 modem and extra's that was just the running process to do it.
