I could have posted this in the main thread where I got this information from, but something new seemed like a better idea if I were to help a new user right now.
I've recently rooted my Galaxy Prevail and figured I'd post how I did it, and honestly, it was very simple.
I downloaded the Samsung drivers and the KMS zip file here. http://androidforums.com/galaxy-prevail-all-things-root/346918-one-click-root.html
I followed the instructions and it worked well, the only issue was that I had to run the "PrevailToExistence.bat" 3 or 4 times before it actually worked, but that seemed to be mentioned there and was normal.
One of the first things I did was try to remove the "bloatware" or factory apps that were installed by default when you get the phone. First I used some other app, (forget the name) it did work but was more of a hassle to have to type in commands manually to get the apps removed, then I found Titanium Backup. TB does a few things for you but one of its functions does include removing apps in a simple point-and-click kind of way, that was much easier. If anyone has any questions, I can help.
I need to stop jumping the gun on these posts thinking everyone needs help and just to read more thoroughly. As yall can see I don't like reading much so I tend to make up my own stories in my head
