borikua787
My prevail is stuck at the boost mobile screen. It is rooted and I tried putting it back to factory default settings. No LUCK. Trying using the recovery util using update.zip I found in the forums but stops and installation is aborted with status 7 code. I also see within the error message the following:
apply_patch_check ("system/app/magicsmokewallpaper.odex", "c9e4f690cee20438e8cd484f79788b114fc93519", " 8df6417d06f14dfc8873e26be996920b94615d0b") E: Error in /sdcard/update.zip (status 7) installation aborted
v/r
