Don't think so. I like the fact the screen turns on. It tells me the Evo is still fully aware of the charger.
If the screen didn't come on, then you may not be sure that it charged properly and didn't just die on the charger. That can happen if the for some reason the charger wasn't plugged in properly, or the power strip it was plugged into was turned off.
I'd rather have it acknowledge it was unplugged from a power source. That can prevent a false assumption that it was charged when it was not, only to realize too late when you are outside and can't plug it back in.
That's a subtle notification, having the screen go on or off is better confirmation, especially if in a rush about.Don't you already have the LED indicator in the top left which should be green when fully charged?
