Prl 3023
It didn't make a big difference with prl 3022, I don't think that prl 3023 will be a big improvement but let us see what will happen. Can you upload it?
I had 3023 last nite. Have been having little issue w Wifi, data3g n MMS -yesterday reflashed ROM n noticed my PRL=3023, BUT data showed 1x:confused:, not being happy bout that, I *228 thinking I'd get 3020 again (which would gave me 3g b4) but instead back down to PRL 3019 n 1x :(:mad: --now working on updating my PRL (have tried *228 several times, still same).
Edited to add: Manually updated PRL to 3020, still showed 1x -updated again to 3022 and now back to 3G. I'm in Central FL, so if by chance I do get 3023 again and it shows 3G, and not 1x like it did last nite, will post.
I believe you cus I had it last night, but I only was getting 1x (when I was always @ 3G w 3020) so I changed it to 3022. Are you showing 3g or 1x
If you had it then post it HERE or the PRL just took a plane and went to Cancun Beach?
The way to post pics up on here is get photobucket upload ur pic to it. Then go to photobucket on ur browser. Login click the pic it will say get URLs. Then click the image URL copy. And paste it in ur post on here. And it will post the pic. :)
What did u use to flash the prl lgnpst or qpst? Does one program write the prl better then the other?
Hi ghost.rider. I used QPST following Santia213 n Ladylock's thread. Personally I prefer QPST. Tried lgnpst -got error -was going to try again, but felt it had more steps than QPST. Maybe didn't give it a chance n would use in future. But for now QPST worked the best - fast and easy to follow. Esp. Santia213's thread very detailed. :)
Just wondering. Is it possible to edit a prl from another carrier with 3g evdo and config it to work on our phones and get 3g evdo?
