Here's a few
http://cid-eabe29f3770d8d15.skydrive.live.com/browse.aspx/.Public/PRLs
I'm looking for 60680 if anyone knows where i can find it to save on SD. Is 60680 the latest one by chance?
I may also make a suggestion when you update, or downgrade your prl you "should" do the same for your nv.
I know you can run different prl and nv versions, it was suggested to me a while back by akazabam to keep both of those the same.
If you do decide to play around with these make sure your battery is charged, and that you have a good nandroid with your Wimax keys.
Also when you flash these you have to reboot in between flashes. You can't flash both the prl and nv in the same recovery session.
UNDER NO CIRCUMSTANCES DO YOU PULL THE BATTERY WHILE FLASHING THESE. Be patient when you reboot, it takes a hot minute for the phone to update. This is one of those rare operations that can brick your phone. Be careful!![]()
