I ordered the new Pro Clip holder with tilt swivel mount. Problem: You have to remove your case in order to mount it. WTF? Doesn't everyone have atleast some sort of case on their Droid / EVO? Maybe I'm way off here...
EVO
EVO
If you want a quality custom solution for your vehicle so you don't junk up your car with windshield mounts, things sticking up from the top of your dash or screwing with cheap vent mounts and ugly *ss ratchet grip holders, then go on the cheap. I have a nice car and prefer a clean dash setup. And you can go with a panavise mount for under $20 on ebay along with the adjustable mount and be around the $60 mark. I'd do that over the "official" mount any day which is useless with an encased phone.He may have bought the wrong one but at $80, it still misses the mark.
meh. $80 buys a lot of duct tape...
It only misses the mark at $80 because he didn't go through me to make it cheaperIf you want a quality custom solution for your vehicle so you don't junk up your car with windshield mounts, things sticking up from the top of your dash or screwing with cheap vent mounts and ugly *ss ratchet grip holders, then go on the cheap. I have a nice car and prefer a clean dash setup. And you can go with a panavise mount for under $20 on ebay along with the adjustable mount and be around the $60 mark. I'd do that over the "official" mount any day which is useless with an encased phone.
No I do not have some kind of case on my phone. That Is all...
are you making a statement or asking a question?
Hey Steve,
There should be a sticker (has the item # on it) holding the nut in place so the center screw engages it. I know I've rippped mine off over time and I just hold the screw in place until the screw engages. Or you can just take a small piece of tape or a small sticker and keep it in place. Though glue work just as well. If you have any problems, let me know.
that's why I always suggest the adjustable, especially when you know you'll want some dual core goodness at some point. It's a waste of money to buy the specific holder for most of the phones out there now that don't have a microUSB port on the bottom sides.
If you want to save a few bucks, let me know. You can always keep the standard holder or throw it up on ebay to make a few bucks back.
It only misses the mark at $80 because he didn't go through me to make it cheaper![]()
