Pretty sure that if you want to unroot you gotta use something like root explorer to go into the system folder and delete the sbin folder then uninstall su then factory reset. That should do the trick if you're trying to undo root for an exchange/return.
Well now I know that, lol. That's not the case though. Phone was just getting really cluttered and bogged down. I'm too lazy to delete things separately. Lol. Its running great now though. (Had way too much shit on here)
