Root problem batery
playsat18
Member
help someone with no prior problems with his battery lasted me over 7 hours without any problem but I changed mumber tow wing rom 1.9.1 (vzd) battery does not last that anyone knows??
are you saying that you are running ROM Number two? if so, the battery does tend to drain a bit faster. 1.5 and 1.7 work better
Just keep everything in one post to make things easier and less confusing.
With 1.9.1 I was getting 15-20 hours on my phone.
The battery consumption lies in the person using the phone :)
What are you saying?
J/k. Never heard of that problem.... anytime I flash #2 my battery lasts hella long. How big of a difference? Haveyou turned anything on (location GPS etc) did you flash a different kernel?
