I tried that but still no luck. It just keeps searching and not pairing. Thanks for the advice.Make sure it is set to discoverable
Not sure what that means? I have never used bluetooth before I bought this car.Are you rooted or stock
Thanks for your help I will look later and try to find that.I got to dig through the archives and my brain. We had a member that had that very same problem. He figured it out. Right now I cant think for the life of me which phones forum he was in. Something to do with clearing/wiping any old settings in the phone from another blue tooth device, and resetting the one in the car? Try the search box and search: car Bluetooth
I've still got a bunch of forums to look in on before I can commit to a search.
I am not the most tech savy. What is a rom? Can I add Harmonia 1 to my phone? Thanks for your help.Some of the roms are not as compatible.
Harmonia 1 seems to be the best in terms of bluetooth connectivity.
