Help Problem staying connected to Wifi
Hi, I've been having a problem just recently with my s2. This has never happened before, so I'm pretty much at a loss as to what to do.
It wont stay connected to my wifi at my house. Specifically, it keeps connecting and disconnecting up to multiple times per minute. But these quick fluctuations in connectivity don't seem to be recognized by my phone. The wifi symbol at the top of the phone doesn't change, when I'm in the house it appears to be connected with all the bars. In the wifi menu, it always says it has a strong connection. The only clue and hint is that on the menu where it shows the list of wifi connection options, the scanning symbol with appear off and on constantly. This is the only thing from the phone that shows me it is having connection problems.
I will go on the internet and it will load 1 or 2 pages normally, and then it will disconnect and I won't be able to load anything else until it reconnects the next few seconds or a minute later. Skype is constantly going offline and back online.This makes it not only frustrating but practically impossible to use the Internet on my phone when on the wifi in my house.
I hope I can get some help here to fix this problem sooner rather than later, because I've already had to pay a couple extra charges on my bill because I've been having to use up all my data on LTE at the house when I shouldn't have to. So not only is this problem annoying, but it's costing me a good amount of money. I appreciate any help you guys can offer.
The computers are connected normally to the wifi with no problems, by the Way.
Have you recently downloaded anything? Try to delete the connection reboot the phone and the router. Then try reconnecting.
