Root Problem trying to root, weird error message
So, i am trying to load a rom onto my eris, and im using these lines in command prompt
adb shell mount -o rw,remount /dev/block/mtdblock3 /system
adb push recovery-ra-eris.img /sdcard
adb push flash_image /system/bin
adb shell chmod 755 /system/bin/flash_image
adb shell flash_image recovery /sdcard/recovery-ra-eris.img
and after the line
i get this error:
Code:
mtd: read error at 0x00000000 (Out of memory)
mtd: read error at 0x00020000 (Out of memory)
mtd: read error at 0x00040000 (Out of memory)
mtd: read error at 0x00060000 (Out of memory)
mtd: read error at 0x00080000 (Out of memory)
mtd: read error at 0x000a0000 (Out of memory)
mtd: read error at 0x000c0000 (Out of memory)
mtd: read error at 0x000e0000 (Out of memory)
mtd: read error at 0x00100000 (Out of memory)
mtd: read error at 0x00120000 (Out of memory)
mtd: read error at 0x00140000 (Out of memory)
mtd: read error at 0x00160000 (Out of memory)
mtd: read error at 0x00180000 (Out of memory)
mtd: read error at 0x001a0000 (Out of memory)
mtd: read error at 0x001c0000 (Out of memory)
mtd: read error at 0x001e0000 (Out of memory)
mtd: read error at 0x00200000 (Out of memory)
mtd: read error at 0x00220000 (Out of memory)
mtd: read error at 0x00240000 (Out of memory)
mtd: read error at 0x00260000 (Out of memory)
mtd: read error at 0x00280000 (Out of memory)
mtd: read error at 0x002a0000 (Out of memory)
mtd: read error at 0x002c0000 (Out of memory)
mtd: read error at 0x002e0000 (Out of memory)
mtd: read error at 0x00300000 (Out of memory)
mtd: read error at 0x00320000 (Out of memory)
mtd: read error at 0x00340000 (Out of memory)
mtd: read error at 0x00360000 (Out of memory)
mtd: read error at 0x00380000 (Out of memory)
mtd: read error at 0x003a0000 (Out of memory)
mtd: read error at 0x003c0000 (Out of memory)
mtd: read error at 0x003e0000 (Out of memory)
mtd: read error at 0x00400000 (Out of memory)
mtd: read error at 0x00420000 (Out of memory)
mtd: read error at 0x00440000 (Out of memory)
mtd: read error at 0x00460000 (Out of memory)
mtd: read error at 0x00480000 (Out of memory)
mtd: read error at 0x004a0000 (Out of memory)
mtd: read error at 0x004c0000 (Out of memory)
mtd: read error at 0x004e0000 (Out of memory)
mtd: write error at 0x00000000 (Out of memory)
mtd: re-read error at 0x00000000 (Out of memory)
mtd: skipping write block at 0x00000000
mtd: write error at 0x00020000 (Out of memory)
mtd: re-read error at 0x00020000 (Out of memory)
mtd: skipping write block at 0x00020000
what gives?
and after the line
i get this error:
Code:
what gives?
Did you enter one command after the other rather quickly? Seems that some users who did this got these type of errors (you apparently need to allow a few seconds for your phone and the adb to finish-out the operations you are invoking).
Try re-entering the command that reported this error again and see if returns with just a prompt instead of an error. Thanks.
thanks!, loading the rom now!
i guess i have fast fingers ;)
