Root Problem with getting to bootloader
Rajat2615
I decided to flash a new rom today and went with the rom that has CM 7.1 with the ICS launcher by syndroid or something. I liked the rom but i then tried to flash gapps on it because i didnt have that. When i did this and rebooted my phone the load screen kept going on and on for a while so i took my battery out. I was going to go into recovery but when i turn my phone on now, and attempt to get into bootloader, it vibrates 3 times and nothing shows up. I need help to get back to recovery or even bootloader so i can do a factory data reset!! please help ive tried to load a few times now and its not turning on!
are you holding the volume DOWN and power together?
thanks I Figured it out a few minutes ago..but do you know if there is a way i can continue using the new rom i flashed and delete the gapps that caused the problem. I dont want to do a reset because i didnt do a back up for the new rom i flashed?
not sure you can remove a flash after you flashed it. You will probably need to do a whole new flash. Why did you not nandroid before flashing? There is a guide in my signature on flashing it may be a bit tedious however it is the best and proper way to go about it. This will save you many of headaches.
