Problem with Google play store pls help!
Palasbhai
Hello! This is palasbhai from Kolkata /India. Recently I have purchaded a Byond mi3 tablet from loal market. The tab runnig on ICS 4.01.03. I have loged in Google store and downloaded some softare like AVG anti virus etc. But some reaonI ave to tgake the yabto the company showroom whnere they made the tab reset on factory mode. From them IN unable to find the applic ation I have dolwnloadcedc from goohle stgorfe. And annoying is thatg when I am login to my google a/c the my android application shows that all the software are installed... but I do not find tnem in tab. When I wsant to remove from the tab from itg shows it will unistalled shortly but do nothing when I wantto install new application it shows the application will shortly downloadcedc to tab but happen othing. I c an not log in tostore with oher id of google . And built applications also not working, I have to browse with built in browser. please HElP!!!
Hey there and welcome to android forums!
Try giving the play store a data clear, reboot and see if it's still doing the same thing
Thanks for joining
Many many thanx for the reply... but I tried that also. I can not data clear my play store either. Can you please give step bystep procedure! Whether I should use the desktop win7 or from this byond mi3 ICS tab!
What you should be able to do, go into settings, app manager, then you'll see a tab with downloaded, all apps, running etc
Choose all, navigate to Google play store and choose to clear data
Yes! I have done that. But the google store is with out any effect and can not install the softwere from the store. When ever I am trying to insall softwee fro appbrain the websie just rediect me to the google store... pls help....
Reagards.!!
Jay Thakur!!
If you've made an account on app brain, you should choose to install app and not tap Google play.
Tested for my device and it pushes the install.
Hello every one,
DragonSlayer95 and LilBit I am very greatful to you as you spending your time to solve my Android tablet's problem..
I have tried all your advice's, as Data Clear; made new ID to app brain t; though nothing is working with the tab. realy trhe situation is frustrating. Shall I take thy tab to the Byond shop again?
This is above my head now, it's probably best to take it back to the shop to have it sorted out :)
Sorry that we couldn't get you straightened out :(
Jay Thakur! Okie, no problem.. I am taking back to the shop, actually the shop is very far from our ashram. Thanks you all again...
Palasbhai.
