Root Problem with linpack....
konspiracy
So i get inaccuracy even with the stock kernel is that normal?
I would like some of you to try it just hit the single thread run a few times and see if it shows up inaccurate.
I have to undervolt my phone by a crap load for it to give me accurate results but then i get reboots randomly. Also the incredi voltage app set at boot doesnt work.
i have used cm7 both ticker guy and my own build along with b-kernel and the oc kernel.
I'm on CM7 B08 + TheOC v1.5 122-1024 interactive and get consistent ~41 MFLOPS (except maybe first run, but I didn't notice, nor remember).
If it's behaving like this under STOCK conditions (ondemand, 245-1024 Mhz, NOT undervolted) then it's a hardware issue, get a replacement. Otherwise it could be the out-of-spec values you're running at.
