Problem with lockscreen aspect ratio
NoHatMan
So, I just joined this forum after searching on Google to no avail...
I recently got a Samsung Galaxy Xcover. For the most part, getting used to it has been a breeze, but there's one thing I can't figure out. When I select a picture for my lockscreen, the phone insists on messing with the aspect ratio of said picture. Even if the picture has the perfect aspect ratio for the screen, when the lockscreen is displayed, it just doesn't look right.
It appears to have something to do with the little horizontal bar at the very top of the screen (where battery reserve etc. are displayed). Rather than cropping the lockscreen image, the phone squeezes the image vertically to make room for both it and the bar, meaning that the image looks all distorted. I have tried countering this by stretching pictures on the computer before transferring them to the phone so that, when squeezed vertically, they look right. But since I don't know the exact height (in pixels) of the bar, this process basically amounts to pure guesswork. And besides, there just has to be a less tedious way of getting images to display properly.
I know this is not a major problem, but it still bothers me. Thanks in advance for helping me out.
Try another lock screen there is several in the play store
Thanks for taking the time to reply. Are you implying that I can't use my own pictures as the lockscreen background if I want the aspect ratio to be correct? That doesn't seem right...
no just that it may be simpler to use another lock screen.
Simpler? Possibly. But surely, there has to be a way to make the phone display images correctly, regardless of the source of said image?
Only thing I can tell you is to keep experimenting with the resolutions until you find the right one. There is not a whole lot of support for your particular device. I've searched to see how I could "easily" help you and it turns out there is no easy answer.We have a section on your device but its not very active and I found nothing at XDA. So your choices are limited
