Help Problem with "unable to install on usb or sd card"
Gareatron
This just happened today and I've tried everything. I didn't found a file smdl2tmp1 on my phone so its not that. I don't know what else to do or try.
So it sounds like you are trying to move an app to the sdcard? Does the app support being moved to the sdcard?
It won't let me update any app that's on the sd card. I tried moving the app to phone but that didn't work.
hmm... Then I'm not completely sure.. I usually just leave my apps on internal storage unless they are like 80mb apps... I haven't really messed with moving apps the sdcard though since my OV days... Maybe someone else can you help you out though.
Could be corrupted data on the SD card.
I think the first thing I would try would be to copy everything off the card on to my computer, and format the card.
