So I downloaded the unroot file, installed it onto the SD card (formatted by the phone), and when I load Hboot it finds no update. It just brings up the normal menu (fastboot, clear storage, simlock, etc.). Does anyone know what I'm doing wrong?
Thanks,
-Cyrus
Depending on the download, you may have to extract the zip. Make sure you're not inadvertantly placing a folder of the same name on the card as opposed to the .zip itself. Put it on the root of the SD card.
