Problem -
MartinsD
when i press '3' button on screen keyboard it types '1', when 'menu' button it reacts as 'back' and so on. all functions are kinda inverted. thats horribly annoying!
does it have something to do with the latest update i just installed?
has anyone else experienced a bug like that? (or is it a feature :confused:)
Regards,
Martins
Regards,
Martins
What phone do you have?
Try powering down the phone, pulling the battery, waiting 5 minutes, and then returning the battery and powering up the phone. It's not likely that this will resolve your problem but it will give you a consistent basis to test against.
Was the recent update an OTA update? Or something you downloaded to the phone and manually ran?
