Sigh... same here...
Just updated to latest OTA update this morning.
I have gotten as much as a whopping 205M free on my EVO, but still I get the notification that the phone is low on memory, which prevents the Android Market from downloading anything. I've also uninstalled a bunch of apps, but that didn't help.
I'm also getting constant Google sign-in requests, but typing in the security answer and YouTube password it wants never works.
Again, one must ask the question. Was this patch even tested???
Update #1:
More info here on market not working after OTA update:
http://androidforums.com/evo-4g-support-troubleshooting/180678-android-market-issue.html
I made a bit of progress by pulling out the battery. After putting it back in and booting the EVO, I rushed to the market as soon as the phone let me and I was able to download and install a single application before the dreaded and very wrong low memory error showed its ugly self again. Having to pull the battery, not a fun task on this phone, for each application installation is completely unacceptable, insane even.
As for the weird YouTube login error, I went to Gmail account settings and deleted the YouTube account, went to the YouTube app, and logged in using the Gmail account, which for some reason worked, although re-entering the actual YouTube account settings definitely would NOT work. Strange, but the YouTube app is now working with my YouTube account using my Gmail login. It seems as though something got scrambled after the OTA patch, although Gmail still works and receives e-mails.
On the positive side, Pandora seems to be working again, the touch sensitivity is nicely back to pre-Froyo, and the fps cap removal makes the phone use way more responsive.
Now if only we could figure out how to use the Android Market again......
Update #2:
Deleted lots more apps from the market. Finally, the low space notification went away. Seems like the new OTA update has an app number limit imposed on the Android Market. So, if you have more apps than is allowed under the new limit, you won't be able to install any new ones until you delete quite a few old ones.
One strategy is to backup apps using ASTRO File Manager and then install / uninstall them as needed. PITA...
http://androidforums.com/evo-4g-sup...52451-low-space-notification.html#post1397697
So, now, it's not just a matter of how much storage space is available, but how many apps are installed, as well. I had moved every app to the SD card that I could find that had SD support, but apparently that just wasn't good enough. Now this new app limit...
Update #3:
Still confused, actually. Reinstalled a few apps from ASTRO backup, but then got a message in ASTRO saying that there was no more space on the phone, even though Advanced Task Killer and System apps say there's over 120M free on the internal memory. Where else is one to look to see when one is near the limit of apps / internal storage usage???
Update #4:
Just discovered a useful app called "App 2 SD" in the market. It caught a few apps that I had not moved to the SD card yet, although most were very small in size (I had caught the big ones previously). There is a different internal memory size shown at the bottom of the App 2 SD screen, which is a LOT lower than the free internal memory shown in other apps. Also very useful is the "Phone only" screen that shows the gobs of apps that don't have support for SD install. It's quite the long list! Let's hope the devs get with the program and update their apps for SD install.
