Help Problems connecting evo to pc
blwnv8
I can connect my evo to my laptop but I can't select a drive. When I select one of the drives that should be my phone, It wants to try to format the drive. Is my only option to get a micro sd adapter and save all my info on the micro sd and then format it? If I try other ports it comes up as f: drive and when I try clicking on it, it says please insert drive. Thanks
Edit: I'm running windows xp home edition sp2
I can connect my evo to my laptop but I can't select a drive. When I select one of the drives that should be my phone, It wants to try to format the drive. Is my only option to get a micro sd adapter and save all my info on the micro sd and then format it? Thanks
Probably not the phone. The phone will ask you whether you want it to appear as a drive or not to your computer. Did you select that option on your phone?
Yes I did. My phone used to connect just fine. I'm sure its not the phone. It works when I connect it to my buddies laptop.
