Root Problems Flashing MiRaGe 07132013 build
Pondering
Member
Sep 15, 2011
51
5
Tried to flash MiRaGe 07132013 build ran through the process, cleared caches, formatted partitions, flashed zip and GAPPS 20110828.
Get the following response when I try to boot:
Fastboot mode started
gpio_i2c: invalid khz: 0
bl: i2c write error
udc_start()
Only way to get out is to pull battery.
Unable to boot into recovery, safe mode or emergency mode following procedures shown at: LG Optimus V Tips & Tricks
A bit more info. Per wierd fastboot mode started udc_start() - Page 2 - xda-developers
I held both volume keys down then connected USB to my PC. Got a bit farther this time with:
bl: i2c write error
udc_start()
--suspend--
--reset --
-- portchange --
-- reset --
-- portchange --
STALL GET_DESCRIPTOR 128 6 1006 0 18
Fastboot: processing commands
Upvote 0
Noob error.
Learn from my mistakes:
Hit wrong keys trying to get into recovery. Once I finally calmed down and followed instructions to the letter, I got into recovery and restored my last Nandroid backup. Looks like a bad download of MiRaGe Rom.
Once adrenaline level return to normal, I'll give it another shot.
Upvote 0
BEST TECH IN 2023
Smartphones
