benjiharris
Member
Hi guys,
Having problems installing the new update. I have an Orange branded HTC Desire, which has been debranded using goldcard. It also has root which I applied using unrevoked. I did not flash a new ROM though.
So I put in my old SD card I used as my goldcard, and then downloaded the update. I then click install and it restarts, begins doing the unpacking the box animation and then stops and shows a little Android with exclamation mark.
If I press a button it goes into the Recovery mode screen (I think this is what it is called) - called - ClockworkMod Recovery v2.5.0.7, and gives me options:
Reboot system now
Apply sdcard:update.zip
Wipe data/factory reset
Wipe cache partition
Could someone please advise me what to do? I am guessing this might be due to me being rooted?
If I click on the "Apply sdcard:update.zip" option, am I right in thinking this is what I need to do because the update will have saved a file called update.zip on the sdcard?
Any help would be appreciated,
Thank you very much in advance
Reboot system now
