Problems Installing SDK
Jadeziaa
I'm simply trying to download the SDK for rooting/unrooting purposes, not to develop apps with Eclipse, etc. I've downloaded the USB drivers package in the SDK, but when I right click 'My Computer,' go to 'Properties' and go to Hardware, etc, etc, I do not get a yellow exclamation or any other icon next to my phone. Yes, USB Debugging is enabled. So, without the SDK, I cannot download Amon's Recovery Image, etc.
If it helps, I followed all the steps listed here:
How To Root Your HTC Eris
to downloading the SDK.
I understand some 'technological-speak,' but not as much as many of the people here. I'd appreciate it if you used tiny words =D Any suggestions and help would be greatly appreciated.
You might want to check this thread for some helpful tips regarding rooting (including USB connectivity issues): http://androidforums.com/all-things...oot-troubleshooting-guide-htc-droid-eris.html
Funny thing, when I rooted, I did it from my laptop (Windows Vista) and my son's desktop (Windows 7) and had almost no USB connectivity issues. Then, I installed the SDK on a new desktop (Windows 7) and I couldn't connect. The solution? HTC Sync. I think it does a better job of figuring-out what USB drivers it needs and installs them (I was missing a "Win7_x86" driver set).
See this excerpt taken from the above thread:
6. Some users have also reported that installing HTC Sync fixes / resolves their USB connectivity issues. I suspect that it goes through the USB setup a little better than the SDK does. If you want to try that, here is the downloads link for HTC_Sync_2.0.33.exe (its about 39 MB):
* HTC Mobile Phone Support - DROID ERIS by HTC (Verizon) - Downloads
By the way, make sure you are set to Charge-Only also. There's also a few more connectivity (and other) tips in the thread. Hope this helps.
I just wanted to add that make sure you check the usb debugging AFTER you have plugged in the phone to your computer and set it to charge only. Was having similar issues until I tried this and worked first time after...
Yes, the HTC Sync did indeed fix it! Thank you so much! ^^ I'm now back to 1.5 and waiting for the 2.1 release =D
Thank you!
. i am trying to run android in windows.i am facing a prob installing android sdk. the sdk manager just blinks an goes off. plz help
plz help me
krishnahk,
Can you be more specific?
Are you having USB connectivity problems or problems getting the SDK installed (or is it the part of the SDK install where you are downloading components (like the plug-ins, etc))? Its been a little while since I've done this, so I can't recall off the top of my head about the sequence of events...
Have you looked here: Android SDK | Android Developers ?
Also, here's what looks to be a very good walkthrough of it: How-To Install Android SDK On Windows, Mac and Linux
I see there's also some videos on YouTube that walk you through things.
Let us know.
