Root problems wirh Rubix 1.9.5
i installed rubix, went all the way to open the .zip file, and when i rebooted, it just keeps looping the rubicks cube movin around, and doesnt do anything else. have a bricked the phone?
it sounds as if you are stuck in a bootloop....try going into stock recovery(power off phone and power back on but hold power and home at same time until you see a orange triangle)then press the search button
and scroll(using volume rockers)to data wipe and clear your data and then cache...if that doesnt do the trick you will have to sbf .....for those onstructions i would need to know which version your on im assuming .340 but would like to verify just to be safe
yeah sorry, im kinda still half asleep. all is well, but i didnt have my contacts synced with google and they didnt pass over, and i had to manually imput them into the X. thanks alot for the help BTW
good im glad you got it working....you should sync with google its a lifesaver or at least backup assistant
