Root problems with my adb shell.
cb3p0
Member
how do i set it up. whenever i click on sdk tools the prompt comes up but it is just a black screen, and i cant type any prompts, please help
You have to open a command promt and manually navigate to the sdk tools directory.
Example for me
cd /android/sdk/tools
it says path cant be specified, and i installed my phone drivers properly using pdanet also
Are you sure you are manually directing to the correct path.
Here's alittle clearer example. I extracted the sdk to the root of my C drive which is C:\
So my full directory is C:\android\sdk\tools
So in command prompt i could do
Code:
cd c:\
cd android
cd sdk
cd tools
or
Code:
You can also copy the file path to the tools folder from the address bar and "cd" to it.
*Remeber this is an example about where i extracted mine and how to access it. Your file path my be different.*
i am copying the file path right from the folder path and it still says it is not recognized as an internal or external command. why cant i just use the setup sdk app.
Because adb was designed to be run from a command line interface (as far as i know.)
Are you placeing cd in front of the file path?
cd filepathhere
