Root Project Philadelphia (M6 successor)
I just installed lazy and set it to 850 with voltage control. Btw I'm using reqs kernel.. Does the lazy version have the same tweaks as super just not oc'd?
Can't really help or test out the problem my phone can't handle the req kernel.
On another note. PPlazy 2.3.6 alpha
Flashed the Lazy... Looks pretty good, btw. Wound up restoring from an older backup, though, because I had issues with messaging that my APN Fix and Update app didn't correct. I suspect it's not your fault at all, though, as I'm currently with Metro in a primarily Cricket area, and I roam to Sprint (wtf, I know, but welcome to San Antonio). It's still a gorgeous ROM, and I would recommend it to anybody.
Definitely check out what might be causing the Super build to hang though. My phone handles Req's OC kernel well (using OA 2.3 ROM), so I doubt it's a kernel issue right offhand... I have a spare Admire that doesn't have Volume buttons or an internal speaker, but if you have an ODIN flashable package or something maybe I can lend a hand with testing.
you cant use reqs kernel for OA seeing how Spz included a kernel he made himself into the actaul rom zip unless you flashed reqs kernel after you established the rom into the phone?
Quite honestly, I had assumed that Req's kernel was the one included :P You'll have to forgive me, I'm stoned on painkillers for an intense tooth infection.
Buuuuuuuuuut, that's what I get for assuming, right? :P Thanks, qandres, for setting me straight.
I'm having an issue with this ROM, it seems...I reboot my phone via recovery after flashing the ROM, and it sits on the "SCH-R70 Samsung" screen for several minutes and then goes to a blank screen and stays. I can turn on the lights in the buttons, so I know it's on, but it's obviously unresponsive. I have CWM whatever.2.8, overclocked and works smoothly on 900MHz. I used M-Bravo with no issues and loved it, but this ROM seems to hate me :c
My phone says I need a sd-ext and I dont know what that is for how to get it can you make a copy of yours please
Sent from my SCH-R720 using Tapatalk 2
Lol sd-exts aren't something you can copy. What do you need it for?
