Help Proper way to downgrade?
So, I just now updated my phone to the new 2.3.5. I would like to say, I completely hate it. Everything just seems wrong. So, how could I downgrade back to the firmware I was at previously?
If what he said seems foreign to you, it's because you have to root your phone in order to downgrade/rollback to Froyo. You can go here http://androidforums.com/galaxy-pre...turn-phone-stock-factory-updated-11-09-a.html to learn how to downgrade.
After you get back to where you were you should definitely make a nandroid backup. ClockworkMod is hands down way better than the stock recovery. Learn about that here. http://androidforums.com/galaxy-pre...od-v5-0-2-6-file-system-recovery-utility.html
That is not true . You do not need ROOT in order to use ODIN . All you need to do is put your phone in DOWNLOAD MODE ( Starting with a powered OFF device , press CAMERA button and volume DOWN while pressing the POWER button . Hold until the yellow DOWNLOADING appears ) . Then run the ODIN . There are several to choose from in the link I'm providing . I would choose the EE14 Stock Version if I were you . Please follow ALL the instructions provided in the ODIN Thread . Good luck . :D
You mean Volume DOWN
Thanks for that Kouma !! Right in the middle of typing the directions , I looked up and my wife was at the front door 2 hrs earlier than she was supposed to be . SICK !!!!!!!!!!!!!!! :eek: I had 2 get her taken care of then finish typing . It seems got confused along the way . LOL . Corrections have been made to the post . :D
