As far as I know, the recovery ported by pressy4pie is CWM. TWRP was ported by hroark13. I am not sure which one you meant, but I've tested all three (two versions of TWRP) and they all work for me. You should be able to use any one of those for Xperion.
Are you still using the init.d version? When your phone boots up, does it take a long time? I'd suggest trying the binary version because Xperion would apparently load the binary version earlier than it would the init.d version. The commands to stop/start sensord should still be usable, but if the partition becomes available too late, perhaps putting those commands in an init.d script wouldn't be effective (without some long "sleep" time).
As for the zip extraction problem using the binary version, I'm attaching the .md5 checksum file for the latest -sensorfix.zip. Rename the .txt file to .md5. With the .md5 file, the recovery should verify the zip before attempting to flash/install (for TWRP at least, I don't remember whether CWM does so). Let me know if the recovery reports matching md5 but you still get the extraction error.
I have the sensord file in init.d but its sitting idle there, not being initiated as I reported several replies earlier, no change. Phone boot up: not necessarily a long time, normal load time.
For the past week Ive been trying to figure out the usage of this file without success. Apologies, I think Im slow at this. I changed your file extension to .md5. I tried installing it but couldn't find it after the rename process in recovery.
