is there a way to set the proximity sensor to do more and in different apps? For example I would like to set it to skip to the next song while I'm listening to music in the car
So from what I can tell the proximity sensor can only be used to turn the screen on and off while making a call. Seems like a waste of a nifty feature.
Far as I know/can tell that is a great feature. With out that every time you were on the phone you would start messing up your home screen, possibly doing worse to the phone, all without realizing it.
I have the samsung galaxy prevail and it does not have a proximity sensor and the screen disables on calls, which is a pain in the ass if you need to dial numbers or extensions.
