Also its two pulls to get to quick settings.
No two finger pull, just swipe down once then down again
The easter egg isn't worth posting. Its some really strange red and blue shapes. Obviously a placeholder. Maybe a hidden clue?![]()
I think they are trolling us. See the video I posted before, they used some of those clips ☺To get to Quick Settings, I was pulling down the notifications, then just pressing at the top right.
And that is an odd Easter Egg. One blue and one red square/rectangle that keep changing size and shape. If it is a clue, I have no clue.![]()
We'll see. All I did was factory reset from TWRP, extract system boot and radio, and flash.
EDIT:
And she just booted. That took a LONG time.
I'm going to get it set up and play with it for a bit and will have a quick first impressions post in half an hour or so
Dumb question, but I've never flashed a tar zip. Can i do this with TWRP like any other zip? Or do i have to use fastboot. Can someone give me the basics. Or do i dig up instructions for fastboot stock?
I'd try to restore my PA nandroid but I'm about to board a plane and need my phone working when I land on the other side.the tar is just a package. You'd have to unpackage it and flash it like a normal factory image through fastboot. I would also expect that custom recovery may not work to get back to 4.4.4 until they're updated, so be careful.
I kept twrp, but haven't risked backing up or restoring.A buddy of mine was able to get latest twrp to boot on it, though I'm not sure how functional it is. Anyone try flashing the latest binary yet?
