Root [Public Mobile] CW Mod can't mount sdcard?
str1de
I installed CWM-Based Recovery v5.0.2.8
When trying to put a custom rom on my phone by (install zip from sdcard, i get the error E:Can't mount /sdcard/
any ideas how to fix?
or how to get back to stock so i can use touch recovery?
I remember getting that issue... restart the phone and then unmount the sd card from the settings menu, then remount and try again. It might fix it after a couple of tries... Lots of users have had that happen to them in the past and really its just a glitch with CWM itself. To get back to stock recovery, we have that in the all things root section, or at least we should...?
Thanks for the heads-up, Skinnyjeans21 :thumbup: :).
I've moved the thread over to the N860 all-things-root area for you guys--let me know if it belongs in the other ATR area and I'll move it there.
Cheers and best of luck!
A simple solution to this problem in clockwork mod is to partition your sdcard using cwm recovery. Go to "create partition" in cwm and create a small partition of ext. Now your sd card will be mounted. ofcourse copy the zip files to be flashed afterwards.
