Root Pull /system
PhoneMan93
I know its stupid but i was hoping to enthuse people to develop Custom ROM's.
But its just a little program for the lazy people.
It pulls the /system file of your phone.
Only for Windows at the moment.
http://www.mediafire.com/?rgfbbg9fpdr5i07
Extract the pull system.zip
1.) Odin to stock ROM
2.) Turn on USB Debugging
3.) Run pull system.bat
4.) It saves all the files in the pull system folder.
build.prop and development are files that are pulled off your phone too, just telling you so you wont over look them.
Happy ROM developing :)
Thanks to Bloodawn!
P.S. If anyone wants to make one for Linux go right ahead, I will post here and give you credit for it.
pull system.zip
Thanks to Bloodawn!
phone has to be at stock to do this?
people on linux can simply use dd to capture the entire /dev/block/stl12 device to system.rfs and then mount that as a vfat loop device
