Help [Q] Camera dosen't work
max246
I have a problem with camera, last day when I was taking the picture the application freazed.
Then I tried to close the application but only way it was to reboot the phone, after that the camera app dosen't work.
I tried which different app but all give me blackscreen and the log :
01-03 16:34:38.381: ERROR/QualcommCameraHardware(1408): startCamera X: /dev/msm_camera/control0 open failed: No such file or directory!
01-03 16:34:38.381: ERROR/QualcommCameraHardware(1408): createInstance: startCamera failed!
I tried to reflash the radio, reset, reinstall rom ecc.. but nothing. I think the driver or other are delete with reboot.
I tried to install another room , Virtous room , but nothing is changed!
My camera is broken????!!!
01-06 19:30:08.938: WARN/HTCCamera(3124): onCreate()
01-06 19:30:09.018: WARN/IntentManager(3124): from class: com.android.camera.CameraEntry
01-06 19:30:09.018: WARN/IntentManager(3124): mRequestMode = RequestMode.Main, from Camera
01-06 19:30:09.018: WARN/IntentManager(3124): request name = null - RequestName.Unknown_General
01-06 19:30:09.018: WARN/IntentManager(3124): extras == null
01-06 19:30:09.068: WARN/HTCCamera(3124): onStart() - start
01-06 19:30:09.068: WARN/HTCCamera(3124): onStart() - end
01-06 19:30:09.068: WARN/HTCCamera(3124): onResume() - start
01-06 19:30:09.208: WARN/HTCCamera(3124): !!!! @@@@ broadcastStopVoiceRecording() - start
01-06 19:30:09.208: WARN/HTCCamera(3124): !!!! @@@@ broadcastStopVoiceRecording() - end
01-06 19:30:09.228: WARN/HTCCamera(3124): OnResume - reset UI, immediately set mMainLayout invisible
01-06 19:30:09.248: WARN/########## HtcSettingsReceiver ##########(3124): 2011-01-06 07:30:09 249(ms) onReceive-start
01-06 19:30:09.258: WARN/HTCCamera(3124): Block Capture UI - onResume(), and unblock after start preview
01-06 19:30:09.258: WARN/HTCCamera(3124): onResume() - mFocusingState = NO_FOCUSING
01-06 19:30:09.258: WARN/HTCCamera(3124): keyguard is not shown !!!!!
01-06 19:30:09.258: WARN/HTCCamera(3124): OnResume - set mWaitResetSettings to true
01-06 19:30:09.258: WARN/HTCCamera(3124): onResume() - end
01-06 19:30:09.368: WARN/HTCCamera(3124): $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ surfaceCreated $$$$$$$$$$$$$$$$$$$$$$$$$$$android.view.SurfaceVie w$3@47a5f418
01-06 19:30:09.368: WARN/HTCCamera(3124): $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ surfaceCreated $$$$$$$$$$$$$$$$$$$$$$$$$$$ start preview
01-06 19:30:09.368: WARN/HTCCamera(3124): $$$$$$$$$$$$$$$$$$$$$$$$$$$$$ surfaceChanged $$$$$$$$$$$$$$$$$$$$$$$$$$$ w=480 h=800
01-06 19:30:09.368: WARN/CameraThread(3124): CameraHandler Message - START_PREVIEW start mode0
01-06 19:30:09.368: ERROR/CameraThread(3124): open the Camera in start_camera_preview
01-06 19:30:09.368: WARN/CameraSwitch(3124): open main camera
01-06 19:30:09.368: WARN/CameraSwitch(3124): no file - can't switch camera
01-06 19:30:16.130: WARN/HTCCamera(3124): Unknown orientation !!!
I'm afraid it does sound like a hardware issue. Flashing a new ROM should replace all system files on the device so any damaged/missing due to the previous crash would be replaced by new ones.
I installed the new room with ROM MANAGER, I tried to enter in the recorvery console, wipe all and then install the rom but nothing is changed!
Can you tell me how I can reset all?
