Root [Q] Relocking bootloader
bigthree
Do i need to relock my bootloader first to flash or go back to stock rom??
Here's my current phone info :
Android version - 2.3.5
HTC Sense version 2.1
Software number 2.26.707.2
Kernel version - 2.6.35.10-g696f19b htc-kernel@and18-2#1 Tue Apr 10 18:15:52 CST 2012
Baseband version - 47.23e.35.3038H_7.57.39.10M
Build number - 2.26.707.2 CL362953 release-keys
Browser version - WebKit/533.1
*** UNLOCKED ***
MARVEL PVT SHIP S-ON RL
HBOOT-1.09.0099
MICROP-0451
RADIO - 7.57.39.10M
Feb 8 2012, 18:29:31
and i'm currently rooted and cwm installed already, with custom rom installed too. i just want to go back to stock rom, TIA :) pls give me a link for the tuturial to follow.
I don't have the wildfire but I do have the One V so I can give you a good idea. I don't know of any tuts for doing this for the wildfire.
You do need to relock the bootloader... Boot into fastboot, plug phone into pc and and run the following on your computer with android sdk... fastboot oem lock
Phone may or may not reboot.
With phone in fastboot mode and still connected to pc run the ruu program on your pc and it will restock you
You can find all the Wildfire RUU's here.. http://www.htcruu.com/?dir=Marvel_MarvelC
I really can't tell you which but there appears to be 2 RUU's for the VM Wildfire
One is named
RUU_Marvel_Virgin_Mobile_1.37.351.1_Radio_47.10.35.3029H_7.46.35.08_release_188032_signed.exe
and the other is
RUU_Marvel_C_Sprint_WWE_VM_1.02.652.00_Radio_0.94.00.0824_NV_VM_1.25_0815_PRL61007_release_219164_signed.exe
Maybe someone can tell you which one you need. Technically the ruu should run a check to make sure it's the right phone but I can't say for sure.
Sorry I couldn't be a bit more helpful but hopefully this gets you going
alright , thanks for the info.
