Root quadrant scores on NS
2003vstrom
hey guys, I was really surprise with what I saw for a quadrant score, I unlocked my bootloader, rooted, and I installed a different rom, the SupeAosp 6.0 for Nexus S, the rom has the overclock option in it and I have it at 1.3 ghz and the first time it knock down a 2679 then for heck of it I did it again and knocked down a 3022 holy crap I thought my eyes were deceiveing me lol I`m very happy with this phone it fast and snappy and the endless modding, Atrix 4g who?:D also I just ran a thrid one 3118 and the pic is below
Yeah it's great. I have no OC and i typically get around 2600 with quadrant using CM7 with Netarchy 1.3.0.2
As always nothing goes right for me.
B2L as you know im running same as you but with CM7 (7.0.2) and got a quadrant score of 1549. Why so crap?
A reboot has given me the following scores:
2126
2245
2427
2171
Still seems bit of an anticlimax considering your scores.
It really varies by device. Every single one is made differently. I just ran 4 tests in a row side by side with my wife's nexus s.
Hers
2077
2138
2454
2526
Mine
1888
2283
2509
2765
Both devices are rooted and running CM7 and netarchy 1.3.0.2.
The scores get much higher near the end because less processes are running in the background. So it will run much smoother at a higher speed.
I'd imagine B2L has the ext4 hack enabled on his Netarchy kernel. That could be where the difference comes from. Still, you should be getting at least 1600 after you've done your first run.
Figured I'd try the NExus s 4g stock, this is the score i got:
1380...
For some reason that's surprisingly low, did you only run quadrant once? Because that could explain things. The first time it runs there are still apps that can be running in the background which will cause a lower score, i would try running it 2-3 times and judge it off the 2nd or 3rd score.
