Root Quadrant Scores
Bankswood
Android Expert
Can someone explain aQuadrant score? I'm just starting to mess with it and my score was 1736. Good / Bad , does it even make any difference. What am I measuring?
I don't know exactly what each section of the chart means, but it is mostly a processor speed and graphic test under different loads...kind of like a dyno for your phone.
Thanks guys. I just ran it again and got less than 1300. I did not change any setting. Same test different day different result.
Quadrants mean diddly and your device performance should be rated on how you see it operating and running ......don't be worried about quadrant ....if your device runs good then its good if poor then find the problem and correct it ....im not saying this is your case or being rude bankswood but I see so many people worried about their score when it should not be the case ....a version drod released a while back ran great and had low scores and upon release he said the score would be low and to not get hung up on it and people still did,that's nuts ....if it runs good then it does if it don't it don't and no score will change that
