Does BakedSnack come with a custom kernel... Im scared to flash a kernel after what happend last time.
I am scared for you to do anything with your phone after what happened last time!
Most Rom's do in fact come with a kernel chosen by or cooked by that dev. What does the baked snack thread on xda say?
Where is it that you are getting your ROM's? Most of this information you ask for is in the first post of each individual ROM's thread on xda
BakedSnackShack.com
it's right there
Baked Kernel #3: (included in ROM)
-using HAVS voltage regulator
-using netarchy/assassins fps fix *thanks guys for your hard work*
-overclocked to 1.14ghz
-set read ahead value to 4k which results in faster boot
-5 point multitouch *thanks ffolkes*
-tweaked audio gain for louder handset speaker
-tweaked cpu scaling for better responsiveness
-reserverd 5mb to gpu memory *thanks aosp*
-default to 3point if five touch is unsuccessful (fixes no touchscreen issue)
-now with bfq
-using conservative governor for better battery (tweaked)
-tweaked gpu for performance[/QUOTE
Hmm Its not the best included though
well, it really depends on what you want...
he has some others that you can download and flash depending on your preferences. But really really make sure you are comfortable with it. It's honestly not any different than flashing a ROM and I never really was able to figure out how you ended up where you were last time (but glad you got it fixed)
(on your quotes that are not working...the last ] or first [ is getting cut out and that is why they look odd )
As for m last situation that i fixed... before i flashed my kernel i forgot to wipe both Cache's
