Help Question about Beautiful Widgets
efeigenbaum
The BW weather clock freezes on me occasionally and doesn't update the time. Anyone know why it does this and how to fix it?
its due to huawei's low speed, I would recommened you Remove the widget - Turn your phone off - Turn it bk and - Place the widget bk on - Update the widget and it may work.
I started having issues with Beautiful Widgets after a few weeks of use, mostly force closes and weather not updating correctly. I couldn't tell you what the cause was, as I have no idea. My solution was uninstalling that and switching to Fancy Widgets, which has worked perfectly since then.
I use Fancy Widgets as well and have had no problems. It has skins on the paid version and is a all round good app. Great substitution for BW.
Weather and toggle widgets ftw. Been using it for over 3 months. It has the coolest clocks and options.
