Root question about repo sycing
thIsgUy20
maybe i can get a answer here when syncing with a repo (ubuntu to be exact) and the repo stops syncing since im using my phone to tether to my laptop they have a code you can put in to start it back up please tell me when you start it again does it pick up where it left off or starts over? if it does that mean im getting nowhere
ive never synced with a repo or git or any of that stuff
If you are using repo it will sync from the start every time. That having been said, it will be able to start from where it left off (sort of) as it works it's way through the source. When it get's through the total source it will only need to download as the source changes.
This will take forever if you are working over the phone. You are going to be downloading over a poor connection that is limited to 2GB at a slow full speed. On top of that, it will have to start over every time the connection times out. If you are using a laptop, could you use a library or a friend's house to to the initial download and get things started right? Even over WiFi things can go sideways.
ahh man that mean fot the past week ive gotten nowhere dang it. i tether wit my evo v bur idk i guess i gotta wait til i go to a mcdonalds or something
You can always just check out each individual git repository, skip the big ones if you want (kernel, frameworks, packages).
but dont i need all of them? this for ubuntu. its actually for the evo v now cause im waiting for this phone to get cm10.1 but those guys over there didnt help i just wanted to know about repo syncing cause i use my phone to tether and on the ubuntu thing it say '' if for some reason the repo stops midway you can enter this to start it.....'' i just wanted to know if it completley restarts of picks up where it left off
Like I was saying before, it starts over, sort of. It downloaded some stuff, but will need to check what it had before it can contimue. With that being said, if something was updated since it was last checked the changes are downloaded and processed. I had my router in another room and had to download using a bad connection that would cut out all the time. I ended up with a bunch of locked sync processes and when it was finally done there was curruption. That's what I'm trying to avoid for you.
I don't know what Ubuntu needs but you will probably need all or most of them. You could download a zip of the git repositories from github, which doesn't include the version history. There's a zip button right next to the repository address.
Thanks i will go check that out. I got on the free node or whatever it is I've never used it and asked the ppl on the Ubuntu chat and they said it picks up where it lefts off. Imma go check it out and see if i can find the zip
