Root Question about switching themes??
Bowslayer
Just curious about this, seems like Ill be jumping back and forth a lot now that Ive gained some confidence and knowledge.
When switching themes within the same ROM should I Factory reset and/or wipe Cache ,or neither, and just flash the theme I want and be done with it?
Thanks.
Heck no I don't want to.
Seems like I've done it every day this month! Thanks Home Skillet!
Sorry, my sad attempt at humor.
Thanks.
Certain themes modify certain apks while other themes don't modify those same apks. I suggest applying a deodexer built for GB (I'm assuming your using GB) and then apply the theme over that. If you don't do this, you will most likely get a mixture of the themes in your setup.
