Try vlingo. It works much better.
Is there any android voice actions app that doesn't require a data plan?
Well it should work over wifi
yeah, I mean a voice app that doesn't require an internet connection at all and just process the voice into actions and text![]()
yes definitely.
Ever since they updated the voice service mine has been shisty at best.. can't make calls with it at all (it opens up google with search text 'call angie') i can initiate a text but not who i'm texting, i've tried hundreds of times but it never recognizes the name... AAARRRGGGHHH
i think you may have to have your contacts synced to your gmail account
then say call angie, but u have to state whether its home or mobile
to check, in your contacts tick Google, and then edit the contact and see what the primary number is set as, most of the time they are just set to mobile
so "Call Angie Mobile" should do it for you
assuming u have set your voice to text language to english(us) if ur in the uk![]()
