Root question about ZVD
So i have not rooted my lg esteem yet. and i am currently running ZVC. So if i wanted to update to ZVD would it be beneficial? Also ZVD is a stock rom correct? Thanks for your time.
i should also mention that i am very much interested in debloating my phone so any suggestions to which would be the best route to take with what i have currently would be helpful also. should i stick with a ZVC rom or update to ZVD??
From ZVC to ZVD would defiantly be a noticeable improve for you. Now that there are a few ZVD roms available the manual task of removing bloatware is gone.
Dive in..the waters fine:D:thumbup:
So if i upgrade to ZVD am i rooting my phone or is it a stock rom that i replacing ZVC with? what version of ZVD would you recommend
I updated my phone to the stock zvd rom as soon as I got it and I haven't had the same problems as other users with the older roms. I'm happy with the phone and think its great, especially after rooting and trying a couple of the newer ZVD roms. The guide that Fuzzy posted is perfect to get you started.
I'm running the the Broken out 1.1 rom, ZVD version
http://androidforums.com/esteem-all...roken-out-esteem-1-1-w-blitzkrieg-kernel.html
thats my recommendation as a new esteem user and going through the same thing.
ok. so i got the phone updated to ZVD....but i am having issues with getting the root completed. once i connect the phone to the computer and initialize the root process it says connect phone and i cant get it to register my device to start the process....any ideas?
Phone is in usb debugging and drivers are downloaded?
Is your phone on internet connection and NOT mass storage under USB settings?
Drivers are installed on your computer?
Go back and READ the directions carefully because something isn't connected right. :D
